View DvR Database Information
Ensure that DvR is enabled globally on the node.
View all DvR routes on a Controller or a Leaf node.
The Controller node displays all the IP subnet routes configured for that DvR domain. A Leaf node displays all IP subnet routes learned from the Controller(s) for the Layer 2 VSNs in the DvR Domain. It also displays the Host Routes (ARPs) learned from other DvR enabled nodes.
  1. Enter Privileged EXEC mode:
    enable
  2. View the DvR database.
    On a Controller:
    show dvr database [home]|[ipv4 {A.B.C.D}]|[l3isid<0-16777215>]|[nh-as-mac]|[remote]|[vrf WORD<1–16>]|[vrfids WORD<0–512>]
    On a Leaf node:
    Viewing the DvR database for a specific VRF or VRF ID is not supported on a DvR Leaf node.
View the DvR database on either a Controller or a Leaf node.
Switch:1#show dvr database
                                                           DVR DATABASE
                                NEXT                       L3VSN     L2VSN     OUTGOING  SPB  PREFIX
DEST            MASK            HOP                VRFID  ISID      ISID      INTERFACE  COST COST   AGE                 AREA   AREA-NAME
40.0.0.0        255.255.0.0     Ctrl-1:K:121       0      0         40400     cpp       10   1      0 day(s), 05:44:55   HOME   area-49.0016
40.0.1.2        255.255.255.255 Ctrl-1:K:121       0      0         40400     cpp       10   1      0 day(s), 05:44:55   HOME   area-49.0016
40.0.1.3        255.255.255.255 Ctrl-2:K:122       101    0         40400     MLT-1     10   1      0 day(s), 05:44:30   HOME   area-49.0016
3 out of 3 Total Num of DVR Database entries displayed
View the DvR database for a specific IPv4 address:
Switch:1#show dvr database ipv4 40.3.1.2
                                                           DVR DATABASE
40.3.1.2        255.255.255.255 Ctrl-1:K:121       0      0         40403     cpp        10   1      0 day(s), 05:50:03  HOME   area-49.0016
1 out of 1225 Total Num of DVR Database entries displayed
View DvR database entries for a specific L3 I-SID.
Switch:1#show dvr database l3isid 0
        DVR DATABASE
40.0.1.3        255.255.255.255 Ctrl-2:K:122       0      0         40400     MLT-l      10   1      0 day(s), 05:44:30  HOME       area-49.0016
View DvR database entries with next hop MAC address displayed instead of the system name:
Switch:1#show dvr database nh-as-mac
                                                           DVR DATABASE
40.0.0.0        255.255.0.0     00:bb:00:00:81:21    0    0         40400     cpp       10   1      0 day(s), 05:44:55   HOME       area-49.0016
40.0.1.2        255.255.255.255 00:bb:00:00:81:21    0    0         40400     cpp       10   1      0 day(s), 05:44:55   HOME       area-49.0016
40.0.1.3        255.255.255.255 00:bb:00:00:81:22    0    0         40400     MLT-1     10   1      0 day(s), 05:44:30   HOME       area-49.0016
Variable definitions
Use the data in the following table to use the show dvr database command.
Variable
Value
home
Specifies the DvR database information for home instance.
ipv4 {A.B.C.D}
Specifies the IP address (IPv4) of the DvR database entry.
l3isid <0-16777215>
Specifies the Layer 3 I-SID of the DvR database entry.
The range is 0 to 16777215.
nh-as-mac
Specifies the MAC address of the next hop node instead of the system name.
remote
Specifies the DvR database information for remote instance.
vrf
Specifies the VRF name of the DvR database entry.
vrfids
Specifies the VRF ID of the DvR database entry.
The range is 0 to 512.
